The factory stock Pontiac 4 barrel manifold is all you need for a street car. Testing showed it to be superior to many aftermarket manifolds. Even the highly touted and rare RAM AIR aluminum manifolds weren't all that much better for the street. As stated, the Edelbrock Performer is just an aluminum copy of the factory unit. You can save some weight but a Pontiac V-8 is a very heavy engine to begin with. What year? The early heads would have the large exhaust valves VS the slightly smaller valves used in EGR engines. The EGR manifolds are looked down upon but, again, testing showed there to be very little air flow penalty. A 455 in a G-body is probably all the power you could ever want or need. As a long stroke engine it makes power way down low so do not make the mistake of using a high rpm manifold. Spend your money on something else.
