I posted about this a while back. NO need to find a F Body at all!
1. If original engine Compressor was on passenger side...
you only need to get the soft hoses for a Olds V8 engine (280, 307, 350) and the GM hose adapter kit. The 231 soft hose will NOT work, the compressor was at the 9 O'clock position. The Olds had it at the 11 O'clock position so it matches up perfectly.
Why? Because your condenser lines are both already on the passenger side.
2. If your engines original compressor was on the DRIVER side (such as the case with SBC) you will need to get the condenser and return lines (all the hard lines) from a GBody Buick or Olds engine car. You wont have to bend anything or have anything custom made.
Why? because the condenser in and out lines are on opposite sides.
While you have everything apart clean it out and replace with the new updated green R134a seals. Fill the compressor with oil, and vacuum out the lines once it is sealed, refill with R134a. Don't forget to buy a NEW desicant can or youre wasting your time.
