Suction/discharge hose assy. AC-Delco 15-33598 GM # 1919140684cutspreme said:FYI I laid the four seasons 307 lines next to a shitty set of gm 307 lines I bought for test fit...and the four seaons hoses are different. The bend on the end of the line by accumulator/drier are bent the wrong way and are clearly shorter than gm...So the 307 lines do fit, perfectly I might add. Anyone have or know where I can get a good used or original GM a/c line assembly? Since like everything else for our cars...parts have been discontinued. Also does anyone have an original GM part #? AC Delco # was 15-33598
anthonychacon80 said:84cutspreme said:The muffler that is on the 307 hits brace from a/c bracket to header. The 92 camaro would fit nice if the line going to condenser was about 6" shorter, had a friend that had junk one laying around to mock-up. So far none of them fit perfect. The 307 one I could probably bend a little to clear brace and the 92 camaro one would look cleaner but needs to be shortened. Is it even possible to shorten it? I am afraid to remove a/c brace...only because I already removed the alternator brace, but that would be the easiest
ok that is why yours does not fit. I leave the AC bracket to header brace off. It is "optional". I just made sure to use all the bolts on the front side of the bracket. Besides, the brace does not even work with my type of headers.
The hoses from a 91=92 Caprice also work.
