Going to look at '84 Monte Carlo
loudvolvo
16
im going to look at a '84 monte carlo next week and was wondering if there was anything besides the usual rust areas to look out for. I plan on dropping my 355 sbc and TH350 in it. will i need a new crossmember for the transmission btw?
gs dewd
202
16
Crimora, Va
If your planning on swaping out the drive train then just the body, interior, brakes and steering components should be all you need to look at. As far as the crossmemeber goes it depends on what trans is in it now and if you plan on dual exhaust. If it has a 3 speed auto in it now then the cross member should work. If you want true dauls then you should change to one of the double hump cross members.
maliburacinfreak
449
Evansville, IN
just check it over real close for rust in the body and rear frame rails. if the monte has an OD transmission, youll need a different crossmember. if it has a 3spd, itll be ok but youll have to notch it or replace it if you put duals on it. id go with one of these... http://www.maliburacing.com/iceman/
