That is because you would not listen to us or have me help you! Push rods are one of the last things you need to worry about if you are going to rebuild that engine. Bent pushrods are a product of something else. Abuse or other mechanical problems.Nah that thread can die. Nothing happened in the 2 months except b**bs, frustration, and popcorn.
I did listen. Did every suggestion over, and over, and over. And while they were all good, it ended up not solving the running like *ss issue. The cam was flat, and it has serious mechanical issues. I've also read that after gm switched to the smaller pushrods on the bbc, they have issues with bending/breaking them even in low stress situations.That is because you would not listen to us or have me help you! Push rods are one of the last things you need to worry about if you are going to rebuild that engine. Bent pushrods are a product of something else. Abuse or other mechanical problems.
And I distinctly remember someone saying the stock pushrods in the 454s much past the early 70s were small and liked to bend a lot...
That was me, but what ever. I want more boobies and popcorn!I distinctly remember someone told you back on page 1 or 2 to look at the valve train......
