just use the carrier out of the camaro and I believe just gettin an install kit from summit or jegs is as good as any good luck. 😀Bonegrater said:Are the 3-series carriers hard to find? Would it be easier/cheaper to source a carrier, or just use the spacer? The spacer set-up seems to be pretty solid. I am getting ready to swap out my 2.56:1 set for a 3:42 set out of a Camaro. I hope that will give me a little more pick-up.
Does anyone have any recommendations as far as what I should replace while I'm in there? I've looked at the install kits offered at Summit/Jegs, or is it better to piece together from different suppliers?
Sounds good, thanks.RockSS said:just use the carrier out of the camaro and I believe just gettin an install kit from summit or jegs is as good as any good luck. 😀Bonegrater said:Are the 3-series carriers hard to find? Would it be easier/cheaper to source a carrier, or just use the spacer? The spacer set-up seems to be pretty solid. I am getting ready to swap out my 2.56:1 set for a 3:42 set out of a Camaro. I hope that will give me a little more pick-up.
Bonegrater said:Sounds good, thanks.RockSS said:just use the carrier out of the camaro and I believe just gettin an install kit from summit or jegs is as good as any good luck. 😀Bonegrater said:Are the 3-series carriers hard to find? Would it be easier/cheaper to source a carrier, or just use the spacer? The spacer set-up seems to be pretty solid. I am getting ready to swap out my 2.56:1 set for a 3:42 set out of a Camaro. I hope that will give me a little more pick-up.
