80ELCAMINOFLAKE said:do you know what kinda gears u want to put into the rear? that will help out too![]()
viera said:80ELCAMINOFLAKE said:do you know what kinda gears u want to put into the rear? that will help out too![]()
373.. It's not going to be a track car or anything like that. I just want to have that option.
80ELCAMINOFLAKE said:viera said:80ELCAMINOFLAKE said:do you know what kinda gears u want to put into the rear? that will help out too![]()
What transmission u got, 373 need an overdrive transmission or will suck on freeway!! Rpms will be screaming!!!
viera said:Do i just get a 7.5 posi carrier n swap it out or there's more to it? Thanks for Any help!!
Anubis said:viera said:Do i just get a 7.5 posi carrier n swap it out or there's more to it? Thanks for Any help!!
That's about it and its not as big of a job as most think. You'll need a dial indicator with a magnetic base to do the job right. Both are available at Harbour Freight. You can find good used posi carriers at your local U pick yard.
