Yes, the intakes are the same from the Cadillacs. Inactuallity the VIN Y and VIN 9 86-87 intakes are all the same.
Also, to be correct with the carb you would need a 17086009, not the 17084553 which is for 5A headed motors.
You can turn your 86-87 307 into a VIN 9 by installing a balancer from any 350 motor (that is what they used) and changing the cam and the valve springs,
thats it.
The 7A headed motors run almost like fuel injection and are wayyy better than 5A motors from the factory, in fact the best built GM V8 for fuel economy and performance was the 85-90 307. That is why they put them in numerous Cadillacs and station wagons. Don't be fooled by the port size, torque is where it's at. HP is over rated and means nothing if it isn't backed by torque to move the weight. The later 307's were given a bad wrap by the port sizes and people who assume they understand the technology but they out perform the
H/O's bar none, that is why they got 8.5" rear ends due to the torque output (which is rather rediculous). The swirl port technology makes for a more complete burn which increases the torque output.
If you were to go with a 5A swap you might as well just install a 350 with all the work you have to do for just 10hp increase. And by the way, 10hp ain't much and the 7A headed motor has more torque than a 5A headed motor and at lower RPM (which is not saying much either) but makes for better drivability and fun around the town performance with better fuel economy:
VIN 9 83-85
180 hp@4000 rpm
245 ft-lbs@3200 rpm
VIN 9 86-90
170 hp @ 4000 rpm
250 ft-lbs @
2600 rpm
