I know it's been discussed in the past, but here we go again. What's the best, most user friendly plug and play H4 sets out there for our cars? I'm looking for something better then the stock sealed beams.
Are they a direct swap or did you have to modify your existing wiring or did you need a harness?All the kits are pretty much the same, just different brand names. Don't be tricked by the 55 watt sets, they use 35 watt bulbs cause 55 watt bulbs are very expensive. With 55 watt ballast and 35 watt bulb the light gets scattered. I wouldn't cheap out on the lenses. I have tried the chinese junk lenses that have no light pattern and they are not sealed properly so they leak driving in the rain. I have 4 Hella lenses which have a nice light pattern that lets you see further down the road without blinding oncoming traffic like the cheap chinese lenses do. I use 2 4300K bi-xenon for hi/lo beam and 2 4300K hid for the high beams
