Good for you! At least you have made it some where useful.
Probably nothing wrong internally, unless someone has been in there. CHECK THE PLUG WIRES / FIRING ORDER! like all have said
This may be harsh 😒 If you can't or won't check for TDC and correct firing order you can't be helped. sorry. this is a critical step.
Now When this is done and OTHER EXTERNAL check are done we can move to the inside stuff, timing chain, cam, dist gear.
FYI finding #1 the way I said before and checking where the rotor points may help tell if there is a timing chain /gear issue
In a word NO! ..... unless you just want a bigger engine😎I'm wondering if I should start looking at a different engine. Im not sure if this issue could be caused by something internal or not. I have a new timing chain I can install and an entire gasket set. I'm just wondering what other people's opinion is. The engine itself sounds smooths and rides great when she is driving other than the back fire. No knocks ticks if anything of the such. Starts great and all. Just wondering if the engine is worth putting the time and effort into it or if I should try to find a decent 350 or maybe what I want a 383 stroker. Thank you all again.
