Handling improvement
Any pics of that GTA 24mm rear bar? I also have a 67 chevelle rear end. It's a 12 bolt. I want to get some stability on the rear end and haven't been able to find anything yet. Also where did you get the GTA rear bar? Thanks!!
I bought the bar from a guy parting out his GTA. I'll get some pics but it was real easy to mount. I heated up the ends and bent them in about 1" on each side. If you don't bend them in the ends will hit the lower control arm. I used two 3" (I think) exhaust U clamp with the OEM saddle, bushing and bushing clamp. I used the OEM end links and there is a nice hole in the cross member lip that is perfect to mount the end links to the chassis.
Reactions: Longroof79
Hellwig 55809
