othtim said:If it's choke, then you have to set your choke right.
If it's fuel drainback:
Stock fuel pumps do not always have anti-drainback valves! I know my monte carlo did NOT have an anti-drainback valve in the OE-replacement fuel pump! The anti-drainback mechanism is in the quadrajet carb. There is a spring-loaded filter that acts as an anti-drainback device. If this isn't functioning correct then you'll have a problem. Possible solutions:
Fix the spring in the carb filter thing. Personally, I hate these and always remove them and add an inline filter.
OR
Add an inline check valve.
OR
Buy a fuel pump with a check valve in it.
You can determine if it's fuel drainback by taking the carb off after it's sat a bit. Turn it upside down. If a half cup of fuel comes out of the bowl vent, then it's not a drainback problem! lol
Well the filter cant be the problem! This is a brand new carb for christs sake lmao ! I remember when i took my old carb off and had turned it upside down a lot of gas came out of it though.
