I mean I backed the nut off a little bit until they popped back out. Then I retightened them but didnt torque them down as tight. It made a little difference, the steering feels freeier than when it was torqued to spec.pontiacgp said:-83MONTESS- said:Well I loosened all 4 balljoints and it turns alittle easier. Still stiffer than it was before but im gonna chalk that up to all new ball joints. What is the best way to tighten these? I followed the Chilton manual for the torque specs before but was seemingly too tight. I should add I have Speedway uppers with their bolt in ball joints. Any special procedure?
I don't understand what you mean by loosing the ball joints. When you tighten the nut it has no effect on the rotation of the ball joint in it's socket..If you over heighten the nut that only causes stress in the threaded area as the shaft is tapered and once it's seated it will not move.
