I was checking my timing today and at 3000 rpm it was reading 58 degrees advance. I know small blocks like 34-36 for the most part correct? I think something must be labeled wrong or the timing tab incorrect on the balancer. The car runs well and has zero missing at idle and under throttle. Do you think the balancer is marked incorrectly? If I took 22 degrees out of my timing do you think it wouldn't run correctly?
I have a mild build 355 sbc , mild cam, dart shp heads, Holley 670 street avenger and a custom built 3000 stall converter. I have a 6.75 in harmonic balancer should I switch it to an 8in? Thanks for the help
