So do you mean "initial advance" which would be the base timing before mechanical or vacuum advance is added?Yeah the mechanic said the idle advance was 22 degrees. It starts up fairly easy, no big troubles when it's warm
Yes thats what I meant. Sorry my knowledge on timing isnt all the way there. I'm thinking he forgot to take the vacuum advance off the distributor ..So do you mean "initial advance" which would be the base timing before mechanical or vacuum advance is added?
I don't plan on taking it to the track other than maybe a time or two to see what it does. I think it is stock I was looking into one of these. Do you think and 8in balancer would be better for my application?If the balancer is a stock unit it is possible the outer ring spun on the hub which will throw off your timing reading if this is the case I would buy a nice aftermarket one that has the timing marks already on them and if you plan on going to the track get one that is SFI approved, there are plenty of affordable ones out there.
Can someone speak to the pros/cons of the 6" balancer versus the 8" balancer to answer the OP's question, in case he decides to buy one?.
I've read online from a few resources that an 8in heavier balancer actually made more power than a smaller 6.75 in balancer. I like everything to be new the lower control arms and harmonic balancer are the only original parts on the car...Can someone speak to the pros/cons of the 6" balancer versus the 8" balancer to answer the OP's question, in case he decides to buy one?
To the OP: if you are using an old original balancer, I would suggest replacing it. The elastomer ring between the inner 'hub' and the outer ring of the balancer can dry rot and allow the outer ring to slip relative to the inner hub, which will throw of the position of the timing mark. Worse than that, the balancer can come apart when run hard. A new balancer is cheap insurance.
