Need help with this. Long story short. Have a 62,000 origanal mile 1986 305 that was running to put in my wagon. Was just goning to clean it up and wanted to replace some gaskests and put a steel timing set in (to replace the factory nylon gear) So here is the deal, relaced the timing set pulled the old one off put the new one on just like the old one came off rolled it up to the cam gear dot @ 12o'clock and the crank gear @ 12 o'clock wich i beleive is TDC the #1 piston is at the top of its stroke The #1- I & E valves and the #6- I & E valves are closed the key way on the crank is @ about the 2 o'clock position but the problem is the mark on the 'harmonic dampener' is at about 10 o'clock and 0' on the timing tab is at 12 o'clock. Did I F' sumthin up ? Is this some crazy 80's smog motor BS ? Or possibly did the outer ring on the 'harmonic dampener' spin ? The motor does rotate CCW if I remember right so that kind of makes logic that it would move in that direction. All I know is I would like some input on the subject cause I can't lose any more sleep over it. I want it to run next month when I take my weeks vacation to install it. Thanks.
