Has anyone made a functional cowl induction setup?
5,709
12,216
Meaning instead of air filter sucking hot engine heat.... having filter seal against raised cowl and utilizing the pressurized air at the base of the windshield? If so pics would be great!
Thanks!
There are several schools of thought about how a cowl induction hood functions best. One is what 565 and 83montess have done where they are pulling air in from the cowl to feed the carb. I think that a cowl works best for giving the heat somewhere to go. You might think that means your carb will be feeding on the hot air from the engine compartment but you'll find just the opposite. It will be feeding on the fresh air that is displacing the air that is escaping out the cowl.
If you can appreciate, the car in my avatar makes a TON of engine heat when it's working hard and the air coming out of the cowl will actually heat the windshield. We tried to run with a stock hood and the engine bay temps are just too high - to the point that I have to start pulling timing when city driving.
9,614
12,683
I agree and even though I already had functional fender vents I felt it necessary to get more hot air out which is why I made hood vents also for my Monte.
Tony1968
2,324
5,132
NW Indiana
There's an old article from the 60's when GM was testing a vette with and without cowl induction and inducted knocked some seconds off I believe 0 to 100mph Zora was involved in that case. I wish I could find it but it's been too many decades since I read it
bracketchev1221
1,414
1,653
You’d really have to test it to see if there is any gains. It’s a nice idea in theory but my car slowed down with the air pan.
Zspoiler
Jun 3, 2018
85
55
I plan on in the future buying a 2" steel cowl hood. And using The cowl induction set up I used in my 1979 Z-28 RS as seen in a Hot Rod rod magazine from "back in the day:" How to make a hood scoop functional. I use the base and the stock snorkel set up. A air cleaner lid from a Mopar slant 6. The seal from a 1969 Z-28 and or 1970 Chevelle cowl induction set up .Cut to fit.You can use a stock air filter .E-- 1500.And it should look fairly stock, You could probably start out with the stock air filter base and do the same thing.
vanrah
879
1,189
Near Afton, Wisconsin
Hi Tony & all; This is mine, works UN believably WELL! The down side if ya don't seal it Well the cowl hood will bleed un wanted gases into the pass area. YOu will find that out the first time it rains & ya put up the windows. Ole' Bob.
Zspoiler
Jun 3, 2018
85
55
Cowl induction hoods are fun to watch when it rains and or snows. and watch the rain and or snow flakes do a 180 into the scoop.
vanrah
879
1,189
Greetings Zspoiler & all: Your set up must have something different than mine?? I had thought the same thing until Mother Nature showed me different. Coming back (75 mi) from Car Craft Nat's (2016?). I drove in what weather man say is "training rain" (1-1/2 hours) at 35 40 MPH when most drivers were on the side of road. Heavy rain would be an understatement! So I'm watchin' the rain come off the raised cowl portion of the hood excepting it to turn 180* & I would have pull over to the side of the road too. To my amazement the rain only turned 90* down into the windowshield cowl! Car ran fine, so when I got home I opened the hood excepting a wet air box! To my surprise like ONE drop of water, 99% dry, go figure. Now had I been able to drive faster the higher pressure may have driven the rain into a 180* turn & I would of seen more water enter the air box. But haven't experience that problem either, maybe because it would be a lighter rain when ya can 60-70 MPH. But what I did experience from that torrential down poor (Car Craft Nat's) was humidity vapor getting into the distributor threw the vent (MSD vented cap). And that sets under the air box & is sealed from the open air box. So that moisture was just spray coming up around the engine-trans area kicked up by front tires. From experience, Ole Bob.
Ps: Note hood vents for exiting HOT air, could be bigger!
