My only good option in the dually with camper is a pork chop tank (or 2!) on the bed. Titan makes a plastic one, but I can't modify it for my use and they're damn proud of it. I was thinking of using 14ga steel. Is this under/overkill? Should I have internal reinforcements? I intend for it to gravity feed into the filler neck but also have a shutoff valve. The sticker under the hood says the evap can handle around 100 gallons, so I'd have the top of the tank vented and teed into the factory evap system. I figure I could start with a 4x8 sheet and bend the sides, bottom, and top as one piece only needing to weld the sides on? I think I'd need to fill it from the truck's main tank with a pump. There is not enough space between the camper and truck bed for a decent filler neck, I don't think.
