Wow, that's amazingly quick for an 80's street car. What mods were done to it to go 12.20?
In the 80s did you get to see big block muscle cars like 454 Chevelles battling it out with the new GNs? I think that would have been pretty awesome to witness.
By the late 1980's/early 1990's real "big block muscle cars" were starting to be worth something, so "rich guys" would show up at the track with them and get destroyed and then go back to the weekend car show circuit and brag how their gross HP cars were somehow really "under rated". I attended a few of the Muscle Car Review magazine drag races which promoted stock appearing head to head racing since the 1980's and my nearly stock 225HP convertible 5.0 was faster than nearly every small block @ 14.1.
The fast street cars were all nitrous cars and mid to high 10's you were the king of the track,
To get a turbo regal to run low 12's@110, you just follow the recipe mods that had been on the internet since the early 1990's: replace the dead factory fuel pump, Make an adjustable wastegate (about $6 in parts and tools), K&N cone air filter, port the turbo elbow with a dremel tool, test pipe for the cat, either dump the exhaust behind the test pipe or put on a new cat back exhaust with straight thru mufflers, 237 fuel pressure regulator fuel from a fwd car like a grand am -$5 at the junkyard (for 45psi) then add a chip (like the $25 Thrasher 108), put in rase gas and sticky tires, set the boost to 18-20 psi and you are pretty much guaranteed at least mid 12's.
I was running low 12's before I even bought a scan tool. MPH falls off when the computer retards timing. The trick is to stay conservative and make small changes. You slowly add boost and add octane or lower boost if trap mph began to fall.
