- Mar 14, 2020
- 253
- 28
Well if it's a choice between replacing a gear box and a spindle I'll take the spindle.I had to replace my gearbox
Don't know. Didn't think about it. Won't be able to check till this weekend.how many turns from hard left to center? then how far can you force it to the right?
Thanks. Once I get it up in the air. Had serious dental work done and can't hit my *ss with both hands at the moment because of painkillers so this effort will need to be put off for a few days.Now gotta wonder, maybe put a tape on the frame and check it for square?
1.5 to both sides. Got it up on jacks started the engine and this thing is seriously steering itself to the left (drivers side).Don't know. Didn't think about it. Won't be able to check till this weekend.
Got it up on jacks started the engine and this thing is seriously steering itself to the left (drivers side).Thanks! If it is alignment/geometry would this be corrected by a front end alignment (I would have to take it somewhere) or would it need a more in-depth procedure?
Got it up on jacks started the engine and this thing is seriously steering itself to the left (drivers side).If you put them on the frame the suspension hangs. You want to mimic the car on the ground with the weight on the suspension
Gear boxGot it up on jacks started the engine and this thing is seriously steering itself to the left (drivers side).
Got it up on jacks started the engine and this thing is seriously steering itself to the left (drivers side). It is 1.5 turns to either side from center.how many turns from hard left to center? then how far can you force it to the right?
Well I guess you never know how something works till it breaks (and you have to fix it). Thanks. First time dealing with this.Gear box
