Im using some 113 heads, come with nice valves and screw in studs. they have 58cc chamber heads for higher compression. About what you would find on a ZZ4 crate motor.I'm interested in knowing what are good aluminum heads for a 350 mild mods to engine. Mild cam, edelbrock 650, mechanical fuel pump.
Nice. They come loaded? Is Edelbrock and better?Im using some 113 heads, come with nice valves and screw in studs. they have 58cc chamber heads for higher compression. About what you would find on a ZZ4 crate motor.
I am running these on my mild 355 SBC in my Regal, mine are set up for hydraulic roller.
Everything was in spec and I like the PBM competition valves and all of the rest of the parts are all Comp Cam.SBC CHEVY 350 383 406 NKB-200cc ALUMINUM HEADS 64cc STRAIGHT PLUG NKB-274 | Skip White Performance - We have the best prices you will ever find for aluminum heads, rotating assemblies and strokers
NKB 200cc/64cc ULTRA HIGH FLOW CYLINDER HEADS, STRAIGHT PLUG, FOR SBC CHEVY 327 350, 355 383, 400, 406, 421 ENGINES. Setup for hydraulic roller cams. 200cc RUNNERS, 64cc COMBUSTION CHAMBERS. *** IMPORTANT NOTE *** You may add items into your shopping cart but in order to check out you will have...skipwhiteperformance.com
I have been running them for probably 5 years now and I daily drive it in the summer on nice days. View attachment 219114
They flow pretty well, there is a flow chart for comparison a little ways down in the description I posted.Nice. I just have mild cam. I want to drive it more. They would breathe better too?
