MALIBU Head lights
I usually watch Headlight Revolutions page on youtube, to check out any and all aftermarket headlight and light bulb upgrades they've tested.
I did check out dapper lighting's website and really like those 4x6's with the halo rings that double as daytime running lights and turn signals. I might use those on the wife's mailbu I need to start building...
Headlight Revolution tested an aftermarket headlight made Holley and Morimoto, I think its Holley's retrobright headlight series, I'm planning on getting a set for my Bonneville.
Thanks for your reply !! I will consider the most expensive light on the market!!
And I will check out you tube. Dez
Looks nice too! i want to upgrade all my interior/exterior lights to LED. Know of any interior gauge ones that work with the dimmer switch???
I couldnt help you there since I changed over to an Intellitronix LED gauge cluster.
Although Gbodyledkits.com sells LED kits for interior and exterior. Not 100% sure if they are dimmable or not because not all LEDS can be dimmed with the stock switch. You can probably shoot them an email and find out
Gotcha & Thank you for the direct link.
Reactions: Dezimade
