pontiacgp said:dirtywhiteboy said:Keep in mind if you adjust the lifters before setting the dist back in, it will be different.
I havn't heard of that before, why would the adjustment be different if it was done with no distributor?
dirtywhiteboy said:pontiacgp said:dirtywhiteboy said:Keep in mind if you adjust the lifters before setting the dist back in, it will be different.
LOL Someone told him to mark the position of the dist rotor.......If you rotate the crank to adjust the lifters prior to reinstalling the dizzy, the previously recommended mark will most certainly be useless.
pontiacgp said:it looked like you were saying the lifter adjustment would be different
dirtywhiteboy said:pontiacgp said:it looked like you were saying the lifter adjustment would be different
yes I should have quoted .....and been more specific
bigtmoney said:LOL Someone told him to mark the position of the dist rotor.......If you rotate the crank to adjust the lifters prior to reinstalling the dizzy, the previously recommended mark will most certainly be useless.
This is true, I hadn't thought of that. One thing I would recommend is watching some videos on Youtube, if you rotate the crank at all to see how to identify TDC.
You have to take off the drivers valve cover and make sure both lifters are in the correct position on the #1 cylinder.
