headlight bulb retainer
scarborough
313
67
70
anyone know where I can find this part or have a good part number
87 olds headlight bulb retainer, the picture looks the same but when you enter in the car info it say's doesn't fit. I called doorman was told part is discontinued
I've no way of knowing, but a similar era box body caprice with euro lamps may use the same retainer... and aren't in demand like cutlass euro headers and so may be in a boneyard.
Or used off someone's busted euro headlamp
If you can ever find one, it's GM part number 16507560.
According to the parts book information, it only fits G-47 Olds 86, 87 and 88 model year. That's why it's tough to find them. You may say "wait, 86 had quad sealed-beam lamps" and you'd be right. Recall the 86 was supposed to get the Euronose and Monte SS style wedge shaped mirrors. But at the last minute, that never happened. Of course, that could be why they re-constituted the 1981 grille for the 86.
This is one area that GM NEVER FIXED THE CATALOGS. We're so shocked.
my car does have the Euro clip maybe that's why it so hard find
the salvage yard in my area don't have any g body are old school car.
I wished I lived in the south parting out these old cars can be a goldmine
thanks for the feedback.
If you look up the 16507560 part number on GM Parts Direct, it shows that retainer fits 86-89 Pontiac 6000 vehicles, and *yet* it says does NOT fit the 87 Cutlass (G47) which makes me tend to believe there's likely other 86+ GM composite headlights that use the same retainer, or at least very similar?
RockAuto has the Dorman 42420 for about $5, might be worth getting it to try, or it may be able to be modified to fit? They show a pretty long list of applications too...see below.
So, since the 1987 Olds RWD Cutlass uses the 9004 bulb for both High/Low beams, I looked up the High/Low beam bulb for one of the applications on that list below. (ie; 1986-1991 Cadillac Eldorado). My guess is that since they are the same bulb used, there's a good chance they'll work and it's just a case of the fitment/catalog not being 100% correct? (to 69hurstolds point).
Hope this helps, just figured I'd share my research in case it works out for you.
Cheers!
Buyer's Guide : DORMAN 42420 Headlamp Bulb Retainer / Clip
BUICKELECTRA1987-1990
BUICKROADMASTER1991-1996
BUICKSKYLARK1992-1998
CADILLACBROUGHAM1990-1992
CADILLACCIMARRON1986-1988
CADILLACELDORADO1986-1991
CADILLACSEVILLE1986-1991
CHEVROLETCAPRICE1991-1996
CHEVROLETCAVALIER1991-2005
CHEVROLETIMPALA1994-1995
CHEVROLETVENTURE1997-2005
OLDSMOBILE981986-1990
OLDSMOBILEACHIEVA1992-1998
OLDSMOBILECUSTOM CRUISER1991-1992
OLDSMOBILECUTLASS1997-1998
OLDSMOBILECUTLASS CALAIS1988-1991
OLDSMOBILEDELTA 881987-1991
OLDSMOBILESILHOUETTE1997-2004
PONTIACGRAND AM1986-2005
PONTIACGRAND PRIX1997-2003
PONTIACLEMANS1993
PONTIACMONTANA1999-2005
PONTIACSUNBIRD1992-1994
PONTIACSUNFIRE1995-2002
PONTIACTRANS SPORT1997-1998
