So I bought one of those Acetone headlight restoration kits from Amazon for $30 and decided to give it a try on my Traverse
I had previously polished them earlier and they looked OK but I wanted to see if this kit could make them look better.
And after a lot of sanding from 180 to 1200 grit I then put the fluid in the cup and waited for it to heat up and was amazed that it worked so well similar to the videos I have seen.
This picture it is sanded with the 180 grit
This is the final sanding with the 1200 grit sandpaper
Here is the set up
Then after misting the lens they look like this with no polishing
Here is the set up
