Headlight switch...
Mine doesn't have that.....
The switch also doesn't have that fiber optic wire...so I'm guessing mine just doesn't have it.
I know this is an old thread, but just wanted to add my findings as it may help someone in the future.
The easiest way to get to the bulb for the switch, is to go through the drivers side front speaker mount
1) remove the grill insert ( using a flat head screwdriver)
2) remove the two Phillips screws, pull speaker out. No need to disconnect it
3) you will see a t10 type socket with a grey plastic hood
4) remove grey hood
5) change bulb
6) Reassemble
The socket will only seen voltage in the keyed on position , you will see a blue light in the top left corner of the switch
Hope this helps someone
