I have a 1986 regal limited
recently I upgraded to a semi sealed style headlight with halogen bulbs (not HID)
I added the wiring harness for upgrade with ceramic plugs, 2 relays, grounds
that is designed to go straight to battery, while still connecting to the existing headlight wiring to function with the factory headlight switch.
lights come on and work, but when I turn on high beams, they go off?
relays appear to be functioning correct,
lights on - one relay switches - lights on - all 4
hi beam - first relay switches off - second relay switches - lights off
hi beam again - second relay switches only - all 4 lights back on
am I missing something? should I remove the factory relays? as I am now using the 2 new relays?
