Heat Only What Am I Missing
Looking at the connectors I think its the right harness. The placement of the cables has me stumped. I tried to search online but so far I got nothin..
In the mean time I'll cut the bracket.
That is the right harness. The last picture is the controls under column
Reactions: fleming442
Thanks for taking the time to take those but theres two problems. The photos only show two cables hooked to the control. Both have red tabs. I have 3 cables going to the control. 3 different colors. Only 1 red tab. Im still in the same boat. LOL
Okay let's see if I can muddle this up some more...these pics were taken a few years ago now....
3 connections on the control....blue, black and red..
blue (on left side) and black (on right side) on the top side...
Red on the bottom side..
here are the other ends of the red and black (connections to box)
and not the best pic but the blue (connection at the box) ((to the lower right you can see the other two))
Hope this helps some.
I have pics of the ground connections as well if you need that.
Reactions: TURNA and Rktpwrd
PERFECT !!!!! Thats exactly what I needed to see ! Not so sure about grounds. I only saw one ground wire and that was on the harness coming in from the blower motor and I grounded it to the bolt for the dash on the right side.
This will be together tonight if the clips are still on the control. I didnt notice if they were still there. It saved me a trip to the junk yard tomorrow ! Thank you so much for taking the time to post those !!!
Glad to help out.
Maybe this is still mounted in your car but here's a pic of were the under the column vent cables attach...right in the center of the pic....
and connections circled...
Reactions: TURNA
Glad to help out.
Crap, I hope those grounds to the brace arent really needed ! I didnt notice any ground wires when I stuck the duct back in the car the other day. Now I have to look again !
Thought you might like a quick update ! Control is in. One of the tabs that the cable snaps into was missing from the back of the it though. I guess GM thought ahead on this piece of plastic and positioned posts pre drilled with a hole next to the hole with the tab so the cable can be mounted to them with the typical screws used in the interior. DONE !!
