OLDS Heater Hose Diaphram Device
Frank_C
22
10
I have a 1984 Cutlass Supreme Brougham with a 6-cylinder 3.8L V6. Attached to the heater hose is the device in the attached photos. What is it and where should it be attached? Is it needed at all? Thanks for the help.
airboatgreg
2,870
3,116
It is a heater control valve. Vacuum is applied when HVAC is in the MAX position to prevent coolant from flowing through the heater core.
83StreetMachine
395
819
Central NJ
I see the vac line is broken off in your pic.
Vacuum for it is sourced from a white or gray line from the hvac. Its run right next to the purple vac line. It enters the engine compartment from passenger firewall, under the ac/heater box.
Frank_C
22
10
Thanks for the information. I will investigate closer at this point. After investigation, the line is so brittle and the control valve is very rusty. Can anyone provide a lead on a replacement heater control valve?
HADA442
26
7
Frank:
RockAuto.com has a variety of heater valve options available.
