Hello from Miami Fl. New to olds. family
WilliEGooN
15
1986 cutlass supreme brougham v8 5.0 stock I don't know if its a 305 - 307 it started acting up yesterday I turned on the car & it started shaking & sounded like a diesel car coming out the muffler almost stalling it sounds like it might be a vacuum prob but not sure its never done this also rpm gage was going up & down fast
ATLMonte88
Apr 4, 2012
6
ATL, Georgia
welcome! I had a smilar issue to yours in the past and it turned out to be burned up plugs and wires (someone thought regular grade gas would be okay), might be a good place to start. are you getting any check engine lights?
WilliEGooN
15
not sure if service light works but the car was runing fine now it sounds bad & shaks real bad i think im going to just change wires & plugs like you say & maybe destributer also see what happens Thanks i found out its a 307 olds
lesbaldridge
152
2
welcome as well. i know its a little late, but better latethan never :rofl: . i notice w2e seem to have alot of florida members here, im thinking of starting a florida mambers thread. im over on the other coast, just south of sarasota.
oh yeah, and welcome to the ols family, im an olds guy to. '80 cutty here.
WilliEGooN
15
Thanks allot! & Yes im new to the olds fam. My grandfather had one when I was young "80's Baby" so when I found her I knew I had to get it. She was running good, But started acting up. it shakes tries to stall & starts sounding like a diesel engine when I listing to muffler & smokes a lil when I throttle... I Completely tuned her up rotor, cap, coil, wires & plugs but still acting up. Not sure what's going on but ill always take good advice! Also im super interested in the S. Fla thread feel free to keep me posted...
Dragonist
424
16
Dallas, Tx
The two areas of interest will be the timing , or the head gasket. On my sbo 350 my cap is lined up with #8 on my intake! When I get off work ill try snap a pic for you, as reference.
lesbaldridge
152
2
thats awesome man. heres a link to the florida thread i started yesterday viewtopic.php?f=27&t=37660&p=320325#p320325 , it seems to be taking off already. swing by and say hi.
oldtinsmith
1,896
242
Auburn, Michigan
WilliEGooN,
Welcome to the site!
If you've tuned it up to spec's (as you've stated), and this problem just started all at once, I'd start checking ALL your vacuum hoses (as you stated in your first post?). Old hoses can look good and be bad (leak). Check them for small cracking by bending them sharply and check the entire length of each hose (remember, this checking is free!). Over the years I've had good luck locating "most" vacuum leaks using a three foot length of CLEAN/UNUSED fuel hose. I put some cotton in my bad ear, hold one end of the hose up to my good ear and use the other end to go slowly around the carb base gasket, the power brake check valve, egr valve, and then slowly check each vacuum hose. Listen for a hissing sound! While checking the hoses, also check all plastic hose barbs (such as where the hoses mount on the charcoal cannister, etc.)
Remember, this checking will only cost you some time (unless you need to buy the hose and/or cotton...LOL)!
Doug
lyndon
Oct 25, 2011
52
9
8
kansas city area
Same thing happened tome too. Bought new plugs wires and all that,then come to find out my cam lobes were worn out. Not saying that's ur prob but something to consider
lesbaldridge
152
2
that sucks. a few years ago my mud truck started running doggy. plyayed with the fuel pump, timing, carb , everything. eventually figured out the lobe on my cam that ran my mechanical fuel pump was wore down and was just pushing the rod just enough to keep it running barely, but try to give it some gas and it couldnt keep up. finally figured it out after me and every friend i knew with some mechanical aptitude spent a week scratching our heads and cussing..LOL. ( and swapping a lot of parts and tuning this and that )
