you can drop the rear of the fender down by taking out 1 shim in the top rear of fender open hood the one tall bolt there might be a shim under the fender and loosen the bolt under the rear of the fender you mighr have to add a shim there also the fender is to far in on the bottom there are shims low on the fender you need to open the door you might have to loosen all the fender bolts even the ones in the splash shield jacking up on the front of the frame by the rad support will open the lower fender gap it takes a while don;t be discouraged
