I've had this 442 for a couple weeks and have fixed a lot of the small things that have needed repair but I'm in desperate need of finding a solution for my hot air problem.
The problem is, hot air is blowing into the car at all times. When driving fast, more air is coming in and it's very hot....so hot that the console where the air is blowing down is almost too hot to touch. I've run the controls on VENT and in OFF and regardless, it's brutally hot.
I reconnected a vacuum line to the water control valve and that seemed to help but not much.
I'd just like outside air to flow into the cabin.
What's not working properly and causing this problem? Is a flap not closing?
I can't drive this car anytime but in the evening when it's cold outside.
