Even though my belt driven vacuum pump pulls a constant 28" of vacuum and self regulates itself I still use a canister inline, plus it is usually a good location to put a vacuum gauge to see what the pump is really pulling.
So I installed the CVR 555 vacuum pump , the instructions give 2 options for install one being from manifold to the exhaust port on the pump and then the vacuum port on the pump to the booster.
2nd is vacuum port on manifold to check valve to T fitting then the bottom of the T fitting goes to the vacuum port and the ehxaust stays open and the other side of the T goes to the brake booster
I have it hooked up the 2nd way and the pedal feels like it has vacuum but as soon as u go to move the car it goes back to rock hard, and then same situation as before the vacuum pump. we tested the booster by using vacuum from our iron duke truck and it worked. so should I hook the vacuum pump up the 1st way ?
any tips/tricks? obviously something is screwy
thanks !
It sounds like you loose vacuum the second you hit the gas, which is what naturally happens inside the manifold. The set up strikes me weird because you are pulling a constant vacuum via the pump. I think the pressure equalizes to atmosphere when you hit the pedal because you don't have a one way check valve between the pump and the booster.
I have a check valve unless the check valve is bad... i also only tested it thus far in the parking lot.
how long does the pump have to run to initially build 18-22" of vacuum ?
whats also weird is i have a 242/248 ... .612/.615 110LSA cam in my 01 SS and I have 0 vacuum issues the cam in this monte is smaller
It shouldn't take long, almost instantly. From your original post, I thought the check valve was before the tee. I like to run mine close to the booster. You can try to run the check valve last, or the pump in line between the booster and manifold. It would help to have a vacuum gauge on intake manifold. On snap throttle, it should drop and rise quickly. Crowning throttle should only drop a little and gradually. Just to make sure you have no leaks.
sorry the check valve is in between the manifold and the T , then the right side of the tee goes to the booster the bottom part of the tee goes to the pump
The tee is still weird. You're basically running a non-beneficial redundant vacuum. I wouldn't run manifold vacuum to the booster because it isn't enough. I would try vacuum pump to check valve to booster. A canister/reservoir in line will help too. Other end of pump open, or restrict it.
