Does anyone here have any experience with W-bodies? I'm replacing the A/C compressor on my '99 Buick Century (3.1L). I need to add oil to the new compressor but I don't know what type or how much. :? :?:
Should be PAG 150 oil for use with 134-A , rule of thumb is 2oz for every component replaced. The system called for 8-OZ. if flushed and empty. You don't want to over charge it with too much oil or 134-A 36.00 OZ's or you will damage your new compressor.307 Regal said:Does anyone here have any experience with W-bodies? I'm replacing the A/C compressor on my '99 Buick Century (3.1L). I need to add oil to the new compressor but I don't know what type or how much. :? :?:
Do you know if I need to add any PAG 150 directly to the compressor before installation?tc1959 said:Should be PAG 150 oil for use with 134-A , rule of thumb is 2oz for every component replaced. The system called for 8-OZ. if flushed and empty. You don't want to over charge it with too much oil or 134-A 36.00 OZ's or you will damage your new compressor.307 Regal said:Does anyone here have any experience with W-bodies? I'm replacing the A/C compressor on my '99 Buick Century (3.1L). I need to add oil to the new compressor but I don't know what type or how much. :? :?:
I usually pour it in the accumulator most compressor Mfg's require that you replace it and the orifice tube or expansion valve at the same time.307 Regal said:Do you know if I need to add any PAG 150 directly to the compressor before installation?tc1959 said:Should be PAG 150 oil for use with 134-A , rule of thumb is 2oz for every component replaced. The system called for 8-OZ. if flushed and empty. You don't want to over charge it with too much oil or 134-A 36.00 OZ's or you will damage your new compressor.307 Regal said:Does anyone here have any experience with W-bodies? I'm replacing the A/C compressor on my '99 Buick Century (3.1L). I need to add oil to the new compressor but I don't know what type or how much. :? :?:
307 Regal said:So my question now is: I won't burn up the compressor on the trip there as long as I don't engage it, right?
