86-blk442 said:A little more detail as to whats happening would help..
illregal said:vacuum leak?
Yes the transmission modulator vacuum line should be hooked up. If its just sittin not hooked up it will be throwing continuous vacuum out the hose and may cause the car to die or stall. Make sure all vacuum lines are connected and if they are, it could be as little as playin around with the idle set screw on the carb.cutdog815 said:illregal said:vacuum leak?
Do I have to hook up the vacuum line on top of the transmission
