Make sure that you don’t have lots of gas in your oil (i.e. way over full on the dipstick or oil smells a lot like gas). If not, drive it a while and see if it clears up. If so, change oil and drive it a while.
No you Have Excess gas in your crankcase as you crank it it pulses the injectors and if it’s not firing your flooding the motor when it comes up on the compression stroke it forces gas pass the rings into the crank case and dilutes your oil check your oil and see if it’s over full or if it smells like gasNo I haven’t. I don’t know much at all about cars and I’m learning as I’m going. So basically what you are saying is it’s probably burning oil off the injectors, right?
