Help with Brakes Problems.
I have a 78 Grand prix with Blazer Brakes upfront and 1985 Monte Carlo Calipers in the rear on a Quick Performance 9”.
I can’t get more then 50% Pedal with the brakes. I have a stock Disc Disc Prop Valve from Summit racing.
The master cylinder is stock. I believe that might be the problem. I’ve had it at two brake shops with no luck. One shop said the quick performance rear braided brake lines might be to big.
Everything is new, new stainless steel hard lines up to the rear and new booster.
Can you hook up the Wilwood prop in the OE location or would I need to redo the hardlines.
Or is it just using the stock master is limiting it.
Thank you for any help.
