where on earth do i mount the rear brackets (off the camaro) to the frame of my cutlass for the links????
the g body never had holes to mount the links for an f body bar. it mounted to the sway bars. it'd be easier to get the right g body bar, but as ungn mentioned you'd need stiffer LCAsyeah I saw that. either I don't have the holes described or I'm not looking in the right place. maybe not using the right parts??
the holes that are pointed out in the pictures in the thread I posted a link to were there in the cross member of my GP. They were not meant for the F body bar but they lined up with the F body bar after I bent in the arms on the sway bar a little so they would not hit the lower UMI control arms. If the holes I used for the end links are not there on the cross member then I would have taken 5 minutes to drill a couple of holes. The F body link works better than the G body bar due it works independently of the lower control arms. The F body bar is the same style as the performance aftermarket rear control arms but much cheaper.
Here is a picture of my Spohn pro touring set up that mounts like an F body. I used vice grip C clamps to hold the mounts in place once I had the bar centered. Then I used a torpedo level to make sure I had them straight and drilled the holes and bolted them right up. If you go to Spohn's website you can download the installation guide and see it. Hope this helps,where on earth do i mount the rear brackets (off the camaro) to the frame of my cutlass for the links????
