Thanks. so if only the rear outer is bad would you do a whole wheel well or can I just replace the 5 inches or so of bad area???Nope. Outer wheelhouse.
Where I am pointing... Is this a parting line between inner and outer wheel well? If so it's just the outer very rear portion that is bad. This is towards front of car for reference View attachment 132137
Might not be that bad. Could probably get away with a self made patch there. It's pretty flat. Plus you can buy a patch off rockauto for the body mount piece that's in that seam on the bottom.View attachment 132145
Looking toward back
Are you talking about these?Might not be that bad. Could probably get away with a self made patch there. It's pretty flat. Plus you can buy a patch off rockauto for the body mount piece that's in that seam on the bottom.
I forgot about that post. Exactly.Are you talking about these? View attachment 132148
