Help!!
Ok.. Sorry have been busy at work not much testing or time to get on line also... Tonight bumped pressure to 18 lbs In foot ball seams to have made a difference but not enough... Amd as fpr your questions I am sorry I don't no all the answers but.... Rims are 8 wide not 10 converter was a custom build out of a shop in Detroit supposed to be great ! I am launching at between 3500 and 4000 rpm and fpr the sway bars I didn't mention them because I dont have any none and for tire compond.... I'm there just mt full drang slicks and tha k you all for your input and time
Are we talking about 9 second car or a 12 second car ?? You times will help. The rims are too small for those slicks, not getting a good foot print. Sway control will help (air bag is a poor substitute) I'm attaching an articial on IC, you need to know where your at and the effects.
Tuning 4 Link Rear Suspensions for the Drag Strip
Tuning 4 link rear suspensions can make a car launch quicker and use less horsepower to do it. Which makes you faster, so you win, get famous, and live happy ever after...
So, let's get into it and find out how to do it...
Note: You need at least 45% of the car's weight on the rear wheels to make a 4 link suspension work properly.
Also, get some graph paper. It helps to draw out what we are doing here so you can measure and be able to set up your 4 link the easy way. You don't have to be an artist, just measure your car, height and length of the 4 links, etc. and transfer them to the paper.
Ok, first we need to know what an 'Instant Center' is.
Imagine a line going through the lower control arm extending towards the front of the car. Now imagine a line going through the upper control arm extending until it intersects the lower line. Where this intersects is called the 'Instant Center'.
Where the 'Instant Center' is located in the car compared to the 'Center of Gravity' of the car is what determines how the suspension acts on the car to launch it.
What you're shooting for is a position that will apply just enough force to the tires to make them grab without spinning and the rest of the force will launch the car.
Next we will figure out where to place the 'Instant Center'.
But first we have to locate our '100% Anti-Squat Line'.
Huh?
Theoretically, if the 'Instant Center' falls on the '100% Anti-Squat Line', the rear of the car will neither lift or squat, it will just be pushed foward. That's a good thing...
So let's find it... Imagine a point on the center of the rear tire contact patch. Now imagine a point on the center of the front tire contact patch.
Now take a line straight up from the front contact patch, and have it intersect the height of the center of gravity.
Note: If you need to know the center of gravity of your car, click here: How to find your Center of Gravity
Ok, now imagine a line from that point to the rear tire contact patch. This is your '100% Anti-Squat Line'.
Now then, let's figure out what all this means...
If your 'Instant Center' falls on your '100% Anti-Squat Line', then think of your car having as having a 'neutral' setting. The rear of the car shouldn't lift or squat, and all the horsepower should launch the car.
Now that's in a perfect world... There are lots of variables that affect that, so your car may want a little above the line, or a little below. This is where testing comes in. We'll get to that in a minute.
Now if your 'Instant Center' falls BELOW your '100% Anti-Squat Line', you will have less than 100% Anti-Squat. The rear of your car will squat and the suspension will 'lift' lightening the rear wheels. There won't be enough force applied to the rear tires and the tires will spin.
Now if your 'Instant Center' falls ABOVE your '100% Anti-Squat Line', you will have more than 100% Anti-Squat. The rear of the car will lift and the rear tires will be forced down, sometimes violently if it's too much. This does give more traction, but it's wasting horsepower doing it...
Sometimes high horsepower cars that have too much 'Anti-Squat' will force the tires down very hard for the first several feet but then start to unload the tires and spin when the chassis starts to settle.
Now that we know how it works, let's set it up!
The way most people go about tuning 4 link suspensions is to get it in the general position they figured out on paper. Now experiment by launching the car and having someone watch or videotape it. Watch what the rear of the car and the tires do.
Now you can see what happens and adjust from there...
You're shooting for the tires to hook up without slipping, and for the car to launch foward without it lifting or squatting.
If the rear of the car squats, you want to raise the 'Instant Center'.
If the rear of the car lifts, you want to lower the 'Instant Center'.
Note: A fully-adjustable 4 link suspension allows you to move the 'Instant Center' not only up or down, but also forward or back by increasing or decreasing the angle between the bars.
If your car wheel stands too much, you can angle the 4 link bars closer together at the front to move the 'Instant Center' closer to the rear of the car.
If your rear tires are being forced down too violently you can angle the 4 link bars farther apart at the front to move the 'Instant Center' closer to the front of the car.
Now let's talk about 'Pre-Load'.
You know when you're at the track and see a car launch and it tries to pull the left front wheel up? What you can't see is it's also pulling the right rear tire up, causing it to lose traction. It's more common on large vehicles with lots of horsepower.
What's happening is the torque from the engine and driveshaft is trying to move the car, and the car is twisting around it. It's actually much more technical, but you get the idea...
You don't want this to happen.
That's when you want to use some 'Pre-Load'. If your 4 link bars are adjustable for length, you can do it there.
The first thing you want to do is make sure the upper bars are the same length and that the lower bars are the same length. This is critical.
After you get the bars the same length you need to put them back in and get the car square front to back and corner to corner.
Now the right upper bar sets any type of preload you want. It is the only bar that you adjust! Leave the other three alone.
'Pre-Load' helps offset the torque from the engine. You will usually shorten the top right bar.
Shortening the upper right bar adds weight to the right rear tire. A little does a lot. Try one 'flat' (on the adustment nut) at a time and keep track of how much you adjusted and the results. One-quarter turn can add as much as 50 pounds.
If you want to check your 4 link setup, go to a chassis shop or find someone with portable race scales. Have them put the car on the scales weigh the car with the 4 link disconnected. Then connect the 4 link, preload it and weigh again. Then you will be able to tell if each side is preloaded the same. Alot of tuning can be done this way.
Good luck!
ladder bars and coilovers and your problems are over. lot of suspension guys say the factory 4 link is good to about 11: 0's. factory upper arms are way too short. that factory rear suspension was very good for what it was intended for. i ran 10:teens with that fac. system but was going to bend a lot of stuff so went to ladder bars and coilovers. never heard of the football trick, have used airbags instead. btw, we always ran about 10 to 12 lbs. in our MT's
?????[/real nice 9 inch set up. the attachment is from 2004 issue of carcraft. that is not my 60 chevy launching because my 70 chevelle looked much worse. that looks to be a stock factory 4 link probably with some band aids on it. i cannot find a pic of my 70 yet but it looked like a pretzel when it launched, all twisted up. i ran it that way for about 4 years. foot braked and launched at a high idle. west coast boys called it a flash launch. used a 4500 stall and swapped feet at about 1600 rpm. 16 lbs. sounds like what we ran with radial tires. my race buddy has that engine in his extended cab chevy truck and took me a ride in it and i could not believe that small engine ran that good. still spinning the tires at 60 mph, my first ride in a ls engine. btw i don't know crap about turbo's other they run like hell.
Reactions: Gbodynate
Well... I do have lower controle arm relocation brackets now and anti role bar this has helped greatly but still fighting traction issue sorry for no reply I just didn't have any updates so now I do amd it is improving I feel as if the traction is posible to be gained now but honestly inhave no i dea what i am doing so your right Fleming 442 to a point! I have been trying honestly but knowledge is limmited I am trying to learn and its probably not right amd i am dure most of you guys found out the hard way and I am sorry for that I am trying to cheet as much as I can but now I am to the point I need to start testing and dialing in what I have witch is like everthing besides coils and ladder bars but not sure how to do this so am going to habe to read further in to this instant center thing maybe make some adjustments
This car is not aloud on the track no cage and no drive shaft loop I have beaten 10.9 cars bracket 10.9 car like thats what they do and all they do but... That was last year and I habe previously added 22% more fuel 7 degrees of tyming and a few lbs of boost with bigger turbo. With that being said I am making a little more power than I was then i don't no how much I do No that its between 750 to 900 I no thats a shot in the dark and Might not be any help all of this was with control arms springs and shocks now i have anti role bar and relocate brackets for lower contrloe arms
I think this is just another case of someone slapping some sh*t together, wondering why it doesn't work, asking for advice, and not hearing what they wanted to hear. Seems to happen a lot here.
Yeah.. I mean I did just slap parts in for sure I don't no what could have been said that I didn't want to here but i must have missed it or somthing I am doing what I have been told I am just slow I guess very buys with life car means the world to me and all but I do have other obligations as well... But yeah all thats done just need to Finnish tuning what i have I have pre loaded my rear a little its about 1 turn and car leaves strait dose not want to do donuts when I do a burn out anylonger and leaves good tire black marks all the way down even on both sides but I need to fine tune everything
