Hesitation/Pop at 3/4 throttle, Buick 231
CaliWagon83
1,937
Orange County, CA
Hi guys. Just took the wagon out for a drive last night. It's done this every now and then, but seems to be a intermittent issue. It seems to happen when I'm at about 3/4 throttle. Not "floored" but more than light/half throttle. The car will be going, and suddenly stumble, and make a muted "pop" sound. It will then kind of "clear its throat" and keep driving along. Anyone else had this issue, and what's the possible fix? Thanks in advance.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,974
Socialist NY
check your plug wires
Reactions: fleming442
500/600
1,148
West Virginia
Quadrajet? If so tighten the secondary air valve spring about 1/16 turn. Sounds like it is right on the verge of being lean at that point.
herb
7
2 things to test,
lean mixture or restricted exhaust pressure from plugged cat or muffler
JJake
5
JJake
5
It's lean. More jet or smaller rods. My 1978 Olds that we have had since new did this, dealer couldn't fix. I went up one size on the main jets and the problem went away. Never had to pass an emission test in Michigan.
G-Body Performance Upgrades
