pontiacman469 said:
dont like the quadbog?tuned right they can be the best carb,beats a holley
It's probably a 2 barrel car since it has a 267, so it would be a Dualjet, not a Quadrajet.
As for the question, I first off would keep all that smog crap safe and sound somewhere since the possibility of signing the Kyoto Protocol in the future may dictate emissions testing in your area.
As for the Holley 390, you have to remember that this carb is designed and tuned from the factory to work on a tunnel ram, so it may need to be modified to work well on your 267. It will also require a new intake if you have a 2 barrel, or a ghetto type adapter if it is a 4bbl. For that, I would run something like an Edelbrock Performer as it has a dual bolt pattern. Now if you already have a Quadrajet, there is no real reason to change it provided it is from a small displacement engine (for the idle feed restrictions.). Just get it gone through professionally and be sure the throttle shafts are tight. I would also keep the stock air filter base for a 4 barrel and add a secondary snorkel with ducting to bring in colder outside air. This will flow more than enough air to feed your baby V8, and the filters will last longer than an open element. Plus, SBC's need a quirky offset base for an open element when using a standard 14 in element, so stock here saves you money. I would also go through the HEI and be sure that the advance bushings still exist. It's almost 30 years old, and many of them are very neglected by now.
I run a Quadrajet and a rare dual snorkel 3rd gen Camaro air filter base on my car and like it better than the aftermarket carbs I had in the past. It fits and works better than the Edelbrock, and it requires no funky little adapter parts to make everything work together right. Remember that it is not just the carb and intake you need, you also need brackets for the throttle cable, a TV cable bracket to maintain the right geometry, fuel line and filter, and an air filter spacer if you run the Holley or Edelbrock carbs. All this adds cost to the conversion. It will not make the car run any better than a good, cheap Quadrajet.
