Hi Everyone
Lue
868
46
Los Angeles, california
My Name is Lue, and i'm fom Los Angeles,ca. I am new to this site, and excited to be here. I just recently got a 78 malibu classic with original 305sbc/ th350. When i first got me Bu, she was leaking oil from the Valve covers, leaky fuel pump, and smoking white smoke when i start her up. Sense then, i have replaced the valve cover gaskets, and replaced the old leaky/tired fuel pump. But now, she is having problems turning off. I turn her off, and the engine is still going for a few seconds. How do i fix this? I know that i need to replace my engine, and i'm going to but i'm still putting my penies together. I have found a performance shop that i'm thinking of buying the engine from. Tell me what you guys think?
CHEVY 350 — 325 - 327 - 330 HP
4 BOLT MAIN
MIDNIGHT BLACK CRATE ENGINE
BEST STREET DEAL
$2095 basic price for 4 bolt main
(Pricing ranges from $1995 for 2 bolt main to $2295 for 4-bolt main, depending upon upgrades.)
1955 up to 1986
This Power2® Engine combination would be great in your muscle car, street rod, truck, 4x4 or Jeep. NO core required (except in AZ). This engine is a 4-bolt seasoned heavy duty Chevy Small Block. Engine will run on unleaded fuel. Comes completely assembled.
SEAL POWER HYPEREUTECTIC FLAT TOP PISTONS
Steel forged rods, Nodular crank.
Chrome valve covers, timing chain cover, 5 qt oil pan,
timing flag, NEW polished intake manifold,
Professional 8" harmonic balancer, flex plate.
NOTE: YOU CAN ALSO ORDER THIS ENGINE WITH A 5 QT CHROME OIL PAN. JUST CALL US AND WE WILL BUILD A CUSTOM ENGINE PACKAGE FOR YOU.
ALL OUR ENGINES 327- 350- 383- 396- 427- 454 ARE CUSTOM HAND BUILT.
Call to Order this engine
Toll Free 1-888-766-8044
07:30am - 6:00pm MST Monday-Friday
08:30am - 3:00pm MST Saturday
This Power 2 Engine is totally REBUILT in our Machine Shop by professionals from start to finish.This Power 2 Engine Performance Combination was developed from our over 35 YEARS of experience on MUSCLECARS, STREET STRIPS, CUSTOM TRUCKS, 4x4s, and JEEPS. Phoenix Engine Rebuilders has built over 130,000 quality engines to date.
Warranty and Shipping Info:
This engine has a one year written warranty. Buyer pays actual shipping costs if unable to pick up engine from our shop in Phoenix AZ. Some state freight restrictions apply. Payment due in full prior to shipping. We accept Visa/Mastercard, money orders, cashier's checks and direct deposit. (GET A DISCOUNT WITH A DIRECT DEPOSIT!) Business or personal checks must clear prior to shipping. Arizona residents must add 8.1% sales tax.
NO CORE REQUIRED except in Arizona.
What comes with your Power 2® engine?
Here's a listing of the parts and machine labor for your Power 2® engine from Phoenix Engine Rebuilders.
POWER 2® ENGINE PARTS include:
Power 2 cam kit
Power 2 hydraulic lifters
Power 2 spring set, heavy duty (900, series spring sets)
Polished Intake Included
Heavy duty steel intake valves
Heavy duty steel exhaust valves
Premium positive valve seals, polyacrylate
Heavy duty roller timing chain
Controlled internal oil system (a PER exclusive!)
Heavy duty, high volume Melling oil pump
Heavy duty steel collar oil shaft
Heavy duty oil pickup screen
High quality American Seal Power/SL hypereutectic pistons
PER® High Performance plasma molly rings
Brass freeze plug kit
High quality rear main seal double lip polyacrylate
PermaTorque heavy duty gaskets and gasket set
Main bearings, Tri metal, high quality
Rod bearings, Tri metal, high quality
New rod nuts installed
Cam bearings, high quality 360 Set
POWER 2® ENGINE MACHINE LABOR includes:
PER 4-angle® valve job
Mill-matching surfaced heads
Heavy duty thick wall valve guides
Valve guides custom cut for posi-seals
Jet vat block and magnifluxing
Remove and replace all freeze plugs
Remove and replace gallery plugs
Remove and replace cam bearings
Custom centerline boring of block (true 90 degree V8 centerline)
Power hone to fit pistons and rings
Custom crank Micro polish radius oil holes
Rods pressed off, then heat fitted
Rods checked for alignment
Street balancing
Call Phoenix Engine Rebuilders today to order!
Toll Free: 1-888-766-8044
* Note: When we custom build your engine, you can choose from 15 different colors or you can supply the paint to have your engine painted the same color as your car's finish!
Please note photos may vary from actual product as all our engines are custom built.
the problem is called dieseling. it usually comes from the idle being too high or excessive heat in the cylinders that ignites the fuel. first i would check your carb idle speed and tuning. part of the procedure is checking your timing. one thing that concerns me is the white smoke you mentioned. that's usually water in the cylinders from a bad intake or head gasket. this can cause excessive temps.
reply
It only smokes when my Bu is cold. Now for the not turning off part. It just started happening after i changed the fuel pump..
did you check the carb and timing?
welcome! (you the guy from camarosource?)
ya the smoke on start up is bad valve seals.
as for staying on, dieseling if it started when you got a new fuel pump then you should also do some tuning of the carb, maybe too rich. I had a rich mixture and it happened to me, prob the rich mixture makes it run hot then it diesels.
there should be two screws that are at the bottom of the carb in the front. i always turned them until it ran rough then turned them back 3/4 of a turn.
thanks for the info. I would love to change the valve seals but i need to stop spending a lot of money on an engine that i dont plan to keep. I just need to replace the engine and call it a day. I have 2 more month before i swap it in..
ya true. just live with it and when you get the 350 you'll see the biggest difference.
My car does the same thing when cold aside from the white smoke does it hurt anything or cause any extra wear?
