Guys Please!! I know 205* aint too hot but that is where I stop it from increasing by turning on the Taurus fan. I have a new champion 3 row aluminum radiator too. You cant say my temps should jump up when going highway speed.
There is a couple inches of space on each side the radiator, which is why I'm looking for some of that original insulation that feed air into the rad instead of around it. some pics of that material on a Malibu or the actual pieces is all I need. Thanks anyway.
As others have said, 205 is just fine. But what you're experiencing is an airflow issue. With the fan off, it blocks airflow, especially if it's sealed/cowled to the radiator effectively. It doesn't hurt any to have it run all the time BTW...unless it's an expensive fan you don't want to wear out. The other common issue is missing seals/close-outs around the radiator in the support area. I closed those holes out and dropped my cruise temp by 10 degrees.
