Hey all.. Ive been following the fuel pump location thread. Im wanting to setup a Holley Blue system for my GM Performance H.O. Deluxe 350. I cant afford the Mallory or Barry Grant setups right now. My H.O Deluxe has a Holly 4150 670cfm single inlet carb, Dougs headers, Edelbrock RPM intake. Turnkey crate motor. Nothin major-330 hp..Just a lil cruiser. BUT I wanted to set it up with an electric fuel pump. Im trying to get a handle on how to set it all up. Ive read that the return line systems are the way to go. The Holley system I'm looking at can be setup either way-with a return line or without. All I'd have to do is swap the Holly 12-803 standard regulator for the Holley 12-803BP "Bypass Regulator". Just wanted to know if you could take a look at my lil diagrams and tell me what you think, and if Im headed in the right direction....I have a tank Im getting welded up that has a dual line sump on bottom...All this is for my 1987 Chevy Monte Carlo SS
:!: The JB weld job is getting welded up correctly and pressure tested before installation :wink: :!:
Non return line setup
Click pic for a larger view
Return lline to tank setup
Thanks for any help you can give...Been googling it trying to get armed with knowledge before I start wasting loot on parts not needed. Hope I gave you enough info on my motor. Here's a pic so you can see the possible plumbing. Holley sells a sweet bracket to hold the regulator for my style of carb. It mounts on the passenger side of the carb...I still want to use the summit filter/gauge setup also...
If I went the return line route, Id run the return line back to one of these lines on top of the tank correct?
Thanks for any help..
Warren 8)
Warren 8)
