Holley High Idle Bracket Update
mikester
3,009
3,986
Small town NY
Bought this setup and it seems like Holley screwed up on the design. The linkage hits. Anyone have this issue ? It looks like Ive got to modify the bracket a bit to get the linkage to fit right. Maybe notch it back to the hole or just before.
When I called Holley this was the part number they gave me. 20-9. Says it fits 4150/4160 carbs. Am I missing something ?
Why does your carb have the Ford kickdown linkage on it? You should be able to rotate the kickdown link back out of the way.
Reactions: melloelky
Lever to the rear of the screwdriver blade in your pic is the Ford linkage. Is that what's hitting the bracket, it appears so in your pics
The Holley instruction sheet shows it rotated back to clear
Never got an instruction manual. The carb came on the crate motor.
