Holley Sniper EFI. Who’s running one, any opinions, tuning?
If I take the 12g pink from the old hei setup to use for a holley hyperspark setup does it need a relay?
No, it's straight off the ignition switch= good to 30a or so. I am doing just that on a 75 T/A as a side job.
One thing Holley doesn't mention that I found is the lack of an oil pressure safety switch for the electric fuel pump. It should be on the pink wire of their fuel pump relay- Standard Motor Products PS-64, wire to start, ignition, and pump relay. It will kill the pump if pressure drops too far 3-9psi.
So just so I'm 100% clear I run the 12g pink wire (old distributor power) to a 30 amp inline fuse then to my triggers for the sniper and hyperspark ?
