A cheap alterative and you can turn the dial and close them when you wash your car, plus there are available at your local home improvement store.
Do you have any pics of the underside?Putting the finishing touches on mine.
On mine I didn't want to see any fasteners on the top so I drilled and tapped some holes for bolts them used Loctite to secure them and then cut the heads off before I did my final sanding to blend them in and then painted them black and bolted them on.Do you have any pics of the underside?
This goes for 565 also....
Thanks!
They will be pop riveted from the top. I still have to vinyl wrap the hood and finish paint the ventsCan you explain how they are secured?
Cannot tell from pictures
I used the cardboard from a cereal box to do my initial mock ups.Maybe take some cardboard and or craft paper and try different designs until you decide on what you like
It’s always the simple things that slip my mindMaybe take some cardboard and or craft paper and try different designs until you decide on what you like
