*HORRIBLE SQUEAKING ON START UP*
80$BABY330
13
I HAVE A 1983 OLDS CUTLASS SEDAN W/ CHEVY S.B. 350. I HAVE A HORRIBLE SQEAKING COMING FROM PULLEY(S) WHEN I START UP, IT STOPS WHEN VOLT METER READS ABOUT 12.5-13 VOLTS. NEWER STARTER, NEW PLUGS CAP AND ROTOR, REBUILT 63 AMP ALTERNATOR. MOST TIMES WHEN I TURN ON HEADLIGHTS AT NIGHT OR WIPERS TURN SIGNALS RADIO OR ANY COMBINATION OF THOSE, SQUEAKING STARTS IMMEDIATELY AND VOLTS DROP BELOW 12.5 AND LIGHTS DIM. BLINK SPEED OF TURN SGNALS EVEN SLOWS DOWN! HELP, PLEASE HELP.
navarro
31
see if its a pulley by spraying wd-40 on them. if it stops it pulley
80$BABY330
13
WD-40 WORKS FOR ABOUT 5 SECONDS BUT DOSENT FIX THE VOLTAGE PROB, I WOULD LIKE TO FIND A SOLUTION TO BOTH
navarro
31
you say u just put an alternator on is the belt slipping ?
navarro
31
the wd- 40 is just to to where ur prob is.
80$BABY330
13
NEED TO FIND VIN ON BLOCK TO MATCH BELT PERFECTLY, PWR STEERING BELT DOSENT SEEM TO FIT 100%. WOULD BETTER FITTING BELTS AND A HIGHER AMP ALT FIX EVERYTHING? FORGOT TO MENTION IT REALLY ACTS UP WHEN IM TURNING THROUGH LIGHTS, SO IM PRETTY SURE ITS PWR STEER BELT
