85 B Regal said:Ok, I'll keep the 7.5 in there for now and hopefully I'll find an 8.5 by the time I find a 350 lol. Thanks for the help everybody!
85olds said:I also shattered 2 t5 and stripped 3rd gear out of a world class t5....if in the budget get a tremic tko 600 ( I did and it's holding fine). also get a drive made (truck shop).
jetsetw31 said:85 B Regal said:Ok, I'll keep the 7.5 in there for now and hopefully I'll find an 8.5 by the time I find a 350 lol. Thanks for the help everybody!
Yeah you'll be fine with your 7.5.
I like the TKO's, but i'm gonna upgrade my T5 with a internals kit from Gforce Transmissions. For about $750 the kit will allow a T5 to handle about 600+ hp with ease. Gforce builds 900 HP complete competition T5s.
FE3X CLONE said:My '87 had the 7.5 behind the 455 for years and I've had one behind the 403 in the '81 as well. It's not the HP that will kill them but the torque, weight and traction.
pontiacgp said:The G force gears are cut with less of a helical cut but to hold 600 hp you'll need to upgrade the casing. The force from the gears will twist the stock casing and that's when the transmission will explode no matter what gear set you have. Get a good hurst shifter and that will help save the transmission. The stock shifter give you sloppy shifts and that could damage the tramsission
